2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T21:16:01+00:00
    The firmware update fixed things for me... mostly. It got me from 5WHr to 34WHr. Huge huge upgrade. Thank you Mircorosft! I still would like to make it back up to 42WHr, so maybe a few charge/discharge cycles will fix it? Also, it still says I have 556 cycles on the battery, which is impossible...
    After a reboot im up to 35.91 WHr. I rebooted again to try my luck a second time and it stayed at 35.91 WHr.
  2. Deleted
    2016-08-29T21:21:19+00:00
    As expected, after my reboot, my battery has dropped to 87% and 2h36m, so this seems a bit more accurate. By the time of typing this message, it is now down to 86% and 2h33m, so this appears to be a bit more accurate but by the looks of things, I'm back to normal and I'll get an average 3h out of my SP3 which is great!!
    Hope most of you will get the same result. It's certainly a relief to see my SP3 back to its old self! Good luck everyone.
    2016-08-29T21:25:36+00:00
    Hello everyone,
    Thanks again.
    Mathew
