2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T20:52:32+00:00
    Sure?
    I also have an LGC battery that reports +44,000 mWh (instead of 42,000 something), gives me only 1.5 hours of regular use, and when showing 10% remaining dies within 3 seconds, too quick to even properly shut down. Recalibrating (fully discharge then fully recharge) does not work, all battery tools report the same. 22 months old.
    2016-08-29T20:53:13+00:00
    to me it looks like just the battery level being incorrectly reported.
    modern batteries decide themselves what section of the battery to use so would have been cycling different areas for the tiny amount of power that was being requested from the OS, so hopefully all will be ok.
    2016-08-29T21:10:27+00:00
    The firmware update fixed things for me... mostly. It got me from 5WHr to 34WHr. Huge huge upgrade. Thank you Mircorosft! I still would like to make it back up to 42WHr, so maybe a few charge/discharge cycles will fix it? Also, it still says I have 556 cycles on the battery, which is impossible...
    2016-08-29T21:15:09+00:00
    I went to check for updates immediately after reading a firmware update had been released.
    It is indeed available and I installed it, rebooted and that was 40 minutes ago!! So no matter what way you look at it, it beats the 10 mins or less I reported yesterday or the day before.
    It was stuck reporting 50 mins left with 100% for a while and I've just checked and now, it is still stuck at 100%, but the remaining time is at 3h17mins remaining.
    I'm going to reboot to see if this updates the time as I'm a little bit concern that 10 minutes later, it is still displaying 3h17 and 100% which obviously incorrect and a little bit concerning but it's now over 1h and my SP3 is still running, so it's a great improvement and hopefully, it will be the same for everyone here.
