2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T20:40:25+00:00
    Mines now showing
    Installed batteries
    Information about each currently installed battery
    NAME
    MANUFACTURER SIMPLO
    SERIAL NUMBER
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 34,200 mWh
    CYCLE COUNT 185
    21:35:00 Report generated AC 105 % 35,910 mWh
    so might be getting better slowly..
    2016-08-29T20:44:41+00:00
    Suggest you start a new thread, different issue.
    2016-08-29T20:47:44+00:00
    Can't wait to go home and check mine :)
    2016-08-29T20:49:05+00:00
    Just got the update..  Rebooted and meter says 50%, unplugged it and 10 minutes later I'm still at 50%.   Used to die in 5 seconds after unplugging.  So, it appears that MS did something - amazing that it took this long.  For me the jury is still out as I need to see where I actually get to after full charge.  Worried that my battery got fired with the bad firmware.
