2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T20:26:25+00:00
    Amazing. I am not on AU yet. Is there a chance I will have to update to AU first?
    2016-08-29T20:27:30+00:00
    my device was not showing available updates either but I checked using this https://www.microsoft.com/en-us/download/details.aspx?id=38826 (find firmware tool in the list). seemed to repair and then afterwards my update was available.
    seems to have resolved the issue. fingers crossed.
    2016-08-29T20:28:28+00:00
    Mates, it works here ! Jumped straight from 144 to 34200 mWh after the first boot with the new FW ! AAaaaahhhh....
    2016-08-29T20:29:24+00:00
    My wife has an LGC battery and her surface is older than mine. She's showing 44kmwh full charge out of 42kmwh max.
