2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T20:12:06+00:00
    been on battery now for over a minute (seriously longer than it's lasted for ages)
    battery at 100% 7 hours 36 mins remaining.
    Looking good!
    Installed batteries
    Information about each currently installed battery
    NAME
    MANUFACTURER SIMPLO
    SERIAL NUMBER
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 34,200 mWh
    CYCLE COUNT 185
    Recent usage
    Power states over the last 3 days
    2016-08-26 23:18:39 Connected standby AC 7 % 578 mWh
    2016-08-27 07:46:04 Active AC 7 % 578 mWh
    07:57:17 Connected standby AC 7 % 570 mWh
    15:17:20 Active AC 6 % 502 mWh
    15:18:25 Connected standby AC 6 % 456 mWh
    2016-08-28 08:16:28 Active AC 6 % 441 mWh
    08:22:37 Connected standby AC 5 % 403 mWh
    08:26:48 Active AC 5 % 403 mWh
    08:27:44 Connected standby AC 5 % 403 mWh
    09:34:15 Active AC 5 % 403 mWh
    09:35:37 Connected standby AC 5 % 403 mWh
    17:25:58 Active AC 5 % 403 mWh
    17:30:06 Connected standby AC 5 % 372 mWh
    17:30:13 Active AC 5 % 372 mWh
    18:17:00 Suspended 5 % 410 mWh
    18:21:08 Active AC 5 % 403 mWh
    18:21:34 Connected standby AC 5 % 403 mWh
    2016-08-29 07:52:02 Active AC 4 % 357 mWh
    07:56:43 Connected standby AC 4 % 350 mWh
    08:57:57 Active AC 4 % 334 mWh
    09:03:46 Connected standby AC 4 % 327 mWh
    12:17:52 Active AC 4 % 327 mWh
    12:18:37 Connected standby AC 4 % 319 mWh
    17:40:57 Active AC 4 % 319 mWh
    17:48:43 Connected standby AC 4 % 319 mWh
    19:19:24 Active AC 4 % 319 mWh
    19:31:28 Connected standby AC 4 % 312 mWh
    19:40:13 Active AC 4 % 312 mWh
    19:40:18 Connected standby AC 4 % 312 mWh
    20:37:30 Active AC 4 % 312 mWh
    20:41:15 Connected standby AC 4 % 304 mWh
    20:52:22 Active AC 4 % 304 mWh
    20:54:00 Suspended 4 % 296 mWh
    20:58:49 Active AC 4 % 296 mWh
    21:05:02 Active Battery 4 % 296 mWh
    21:05:10 Active AC 3 % 274 mWh
    21:06:00 Suspended 4 % 289 mWh
    21:07:28 Active AC 6219 % 34,018 mWh
    21:09:48 Active Battery 105 % 35,910 mWh
    21:09:48 Report generated Battery 105 % 35,910 mWh
    2016-08-29T20:16:53+00:00
    Hoping we can get that 34-35kmwh up to 42k again where it should be. Guessing running it down every day and recharging it fully will help cycle that up and get it back up to near maximum again.
    2016-08-29T20:19:36+00:00
    Congrats! I wonder if this is specific to Win 8.1. I do not see an update for my SP3, on Win 10.
    There is no mention of 8/29 on the surface pro 3 update history site.
    Win10 - https://www.microsoft.com/surface/en-us/support/install-update-activate/pro-3-update-history?os=windows-10&=undefined
    Win8.1 - https://www.microsoft.com/surface/en-us/support/install-update-activate/pro-3-update-history?os=windows-8.1-update-1&=undefined
    2016-08-29T20:23:34+00:00
    I'm on anniversary update on win10 and got it eventually.
    be patient, it's replicating through all the MS update servers, could take a while!
    tbh 34k is prob about right for my battery, it's 1.5yrs old.
    been on battery now for 12 ish mins and still showing 100%
