2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T19:58:02+00:00
    No KB# associated. Literally says "System Firmware Update - 8/29/2016"
    2016-08-29T20:03:15+00:00
    Yeo it's coming through on mine now but says battery must be at least 40% to install.
    Annoyingly because of the fault mines saying 4%:(
    2016-08-29T20:05:19+00:00
    Try uninstalling your battery driver, rebooting, and then updating? I don't know. :(
    2016-08-29T20:09:14+00:00
    Was in the middle of doing that when this update came through :)
    firmware installed and battery showing 100% now.
    Time to test longevity....
