2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T19:32:59+00:00
    Just installed the new firmware (windows 8.1, surface pro 3) here at 2:22pm CST, after rebooting I'm active on battery and it's showing 100%.
    Battery report has not yet caught up it seems. But I'm seeing it working properly. We'll see how long the battery lasts.
    Just as a refresher, my battery report has shown 144mwh since about July 1st, and I had been forced to be on direct power since then. Even removing the cable it would shut down immediately from 100% battery available.
    edit: 15 minutes later and still going strong.
    Recent usage
    Power states over the last 3 days
    2016-08-2721:07:28 Connected standby AC 21 % 30 mWh
    21:07:28 Active AC 21 % 30 mWh
    21:58:04 Connected standby AC 100 % 144 mWh
    21:58:05 Suspended 100 % 144 mWh
    2016-08-2821:10:08 Connected standby AC 63 % 91 mWh
    21:10:08 Active AC 63 % 91 mWh
    22:58:44 Connected standby AC 100 % 144 mWh
    22:58:44 Suspended 100 % 144 mWh
    2016-08-2908:35:29 Connected standby AC 100 % 144 mWh
    08:35:29 Active AC 100 % 144 mWh
    09:16:22 Connected standby AC 100 % 144 mWh
    09:22:13 Active AC 100 % 144 mWh
    10:50:56 Connected standby AC 100 % 144 mWh
    10:54:41 Active AC 100 % 144 mWh
    11:16:03 Connected standby AC 100 % 144 mWh
    13:12:46 Active AC 100 % 144 mWh
    14:20:00 Suspended 100 % 144 mWh
    14:24:34 Active AC 126 % 182 mWh
    14:26:06 Connected standby AC 3758 % 5,411 mWh
    14:28:27 Active AC 9817 % 14,136 mWh
    14:29:46 Active Battery 12857 % 18,514 mWh
    14:40:00 Report generated Battery 23624 % 34,018 mWh
    2016-08-29T19:39:29+00:00
    what firmware update did you do? link? I am not showing any available updates when I check on my device.
    2016-08-29T19:48:14+00:00
    I'm on windows 8.1, just did the update through the windows update client.
    2016-08-29T19:52:04+00:00
    Whats the kb number of the update? And the release date please
