2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T16:42:25+00:00
    Thanks a ton Barb.  You have been a huge help in this process.
    2016-08-29T17:17:55+00:00
    Another thing to try if that doesn't work is to keep the surface unplugged for a while then continually try starting it while it is not plugged in. Try to start it 5-6 times. You will just get the dead battery screen, but keep doing it. Then plug it back in and start it up. Sometimes this will also trick the firmware into holding enough charge to log in. My surface is the only computer I have and its been dead for a month, so I have had a lot of time to experiment with it and try to get it working.
    2016-08-29T18:56:04+00:00
    @SeanDavis33 Thanks for the suggestion , but unfortunately it didn't work :(
    2016-08-29T19:17:47+00:00
    I have been following this issue and like most, if not all, of you suffering from this SIMPLO battery issue. With my screen turned down to 25% and Edge open, no apps or processor intensive apps running, I get about 10 minutes of life while on battery.
    However, as of the last couple days a  new issue has come up. Plugged in, my SP3 hibernates or goes to sleep while I am using it. Really frustrating!!!
