2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T15:31:09+00:00
    @netdev2000 you would be correct to worry about getting bricked.  Mine officially doesn't have the juice to launch Windows anymore.  The last time I was able to successfully check, my battery was reporting really low at 140.  It continually 'degrades' or at least the firmware think's it is.  So now this is what happens.  If I unplug it, I get the battery logo.  If I plug it in, I can get to the Surface screen and if I'm lucky my lock screen.  The furthest I've gotten is to enter my password and it goes lights out.  Usually though it's dead before I get to that point.  If I go to the repair screen it will stay up fine, but I can't really do much there.  I've tried it docked and with wall charger and neither are helping.  I now have a $2000 paper weight.
    And yes props to Barb, she has been really helpful and I believe wants to help everyone.  She helped me find this forum and has given me things to try.  Now, I'm stuck though as it won't do anything.  She had mentioned a more powerful charger at a Microsoft store, but the nearest Microsoft store is 2.5 hours away.  Barb do you know if there will be any kind of agreement with like a Best Buy so they can be aware of the issue and help me?  That is where I purchased.  I just don't want to have to pay all kind of service fees and still come up empty handed.  My Surface has been awesome and I love it.  There is nothing like it.  I use it every single day.  But immediately after system/firmware updates, mine started the battery problems.
    2016-08-29T16:29:51+00:00
    Hey, I have the same problem but I have a way to work around it. It's finicky, but it work. Unplug the surface and let it sit for a few hours. Plug it in and then start it up. As soon as you see the surface screen Unplug the cord and quickly plug it back in. Leave it plugged and it should trick the firmware in to charging again, or at least running off AC  power enough to log in. Sometimes you have to do it a few times but I can usually get it to start running off AC power. Also, I recommend buying  the 65W surface charger for $30 on amazon. It seems to happen less frequently when the firmware knows own it's getting more power. Also, as soon as you can log in, go to advanced power settings and change battery critical action to never hibernate
    2016-08-29T16:30:08+00:00
    Bestbuy=unknown. I will ask, but you may need to make the long trip to the MS Store.
    Edit: my contact at Microsoft is checking and will see f he can talk to the right folks to make this happen.
    2016-08-29T16:41:02+00:00
    @SeanDavis33 great tips.  If this works, sending you a beer.  I'll try when I get home.
