2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-29T10:11:28+00:00
    First, you should be able to power on using the power adapter that came with the
    SP3 (but possibly not in the dock).
    If the battery is not being detected, you may have a different issue. Can you
    power up from AC and run
    powercfg /battery report
    and post the results here.
    Second, at this point, I would not advise applying the battery regedit at all.
    2016-08-29T11:17:44+00:00
    I have tried all of these "fixes" as well.  Startup is NOT the issue.  It starts up with either the original power cord or a docking station.  It works fine as long as it is connected to a power source.  It "dies" once it is disconnected with the battery now lasting less than 15 minutes!
    I'm SHOCKED that Microsoft isn't stepping up to HELP!
    Time to buy a product from another manufacturer.
    2016-08-29T13:26:16+00:00
    I'm currently on Windows 10 V 1607 and still having the battery drain issue. Any solutions or further fixes in the near future?
    2016-08-29T13:29:03+00:00
    of course you are still having the issue - the fix isn't out yet.
