2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-28T12:39:36+00:00
    I don't think we'll ever know how many, and Microsoft is less than forthcoming about the problem.  They say it's a software update that has never come out, then it's a hardware failure, but "whoops", your surface is out of warranty so you'll have to buy a new one.  (Isn't that convenient?).  So we'll give you a deal for another surface for only $500!!!  I asked them WHY I would get another surface only to have the same thing happen in a little over a year.  I suspect that EVERY Surface owner will start having the issue shortly after the warranty period expires.  I believe this is a flaw with the battery used.  Why would anyone buy this product?  And why would anyone buy from Microsoft if they won't stand behind their product.  Bad business!
    2016-08-28T23:28:41+00:00
    This is exactly how mine degraded. It was docked on my desk and a month or so ago the battery lasted a few minutes. Now nothing but when docked it gives the battery percent and eventually shows 100% charged.
    2016-08-29T05:37:29+00:00
    1. are you in a dock? I was told that if you don't dock and use your original
    power cord it should boot.
    1. do you have access to the more powerful power supply for a Surface Book?
    2. if you are near a physical retail Microsoft Store, when the fix is available,
    they have the more powerful adapters and they will apply the fix for you.
    H Barb,
    I have noticed that you are taking exceptional care and interest in this issue, hence my question.
    I want to apply the registry tweak(earlier suggested) so the device can function at 65% power input. But currently the battery is not even detected . What is the best way to apply this tweak. How do I at least get the slate to show a battery is installed?
    I m  not powering it on for the fear of getting it completely bricked without being able to apply any fix.
    Thanks in advance.
    A SP3 user in despair.
    2016-08-29T05:57:57+00:00
    H Barb,
    Thanks in advance.
    All of these issues and "fixes" have been addressed at various points in this thread and none of them work. I'm not using the do know and mine doesn't work either. The registry tweak doesn't help either. This issue is starting to also appear in SP4 threads as well. The more powerful adapter only delays the issue. The Microsoft stores aren't being helpful or cooperative at all. Also, while they have recently admitted it was a software issue and stated a little over a week ago a fix was in the works this is following months of going from denying the problem all together, blaming it on the battery/hardware/customer, to denying it was a large scale issue, to charging 500 dollars for REFURBISHED, to where we are now. I have little faith or confidence left in them to do the right thing.
