2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-28T02:20:20+00:00
    If you read this thread and other articles, there is one under way. Where do we find info on the class action?
    Google is your friend (in this instance - not making a generalization)
    I sure hope the lawyers do better than the $100 vouchers they got for the users in the Lenovo case they seem so proud of... frankly that would just **** me off more. Any settlement better include new batteries installed for all Simplo machines at no cost to the user. If they want to add a voucher on top of that to compensate for the hassle they caused and *just maybe* convince me to *possibly* consider their products in the future I won't turn it down. Also won't guarantee effectiveness tho.
    2016-08-28T03:02:26+00:00
    Do you have the numbers how many of those Surface Pros got useless?
    2016-08-28T07:47:57+00:00
    count mine as well :) Went to MS store earlier this morning and they told me that I have to wait till the firmware update , Lol my pro is useless now , I can't make it work without power cord.
    Avi
  4. Deleted
