2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-27T22:05:25+00:00
    I wonder if "Greg" exists.  Perhaps Greg is a troll and this group has no one at Microsoft who can stand the acid generated by this failure.  Perhaps this group is not monitored at all.
    Oh lord, hope thats not the case. But realistically I could be Greg. Or Brian, or Stephen... from Microsoft. That would be a cruel joke.
    M
    2016-08-28T00:00:29+00:00
    @microsoft support.  Is this fix going to be able to run on surface's with a battery life left in the 100's.  Mine is around 200 now and not sure it will stay on long enough for a patch. This is bad that a software bug is going to brick my machine.
    2016-08-28T01:04:16+00:00
    Back in May just as or before this thread started. Once I tried to "fix" my surface's battery issue thinking it was software related, I did a clean install of Win 10, then down to 8.1 and back to Win 10. Made no difference to battery. Originally, the battery wasn't being detected. It evolved to saying it was charged but turning off once power cord pulled. Noticed the battery started to fail after a firmware (thought it was software) update around March/April likes others have attested to. Afraid nothing works that we can do.
    2016-08-28T01:10:03+00:00
    Added note, I work in a large school district. I had personally convinced Surface Pro to be allowed for principals, managers, etc. Sadly as a result of the battery issues and lack of repair support, the District has pulled Surfaces from being allowed. Back to Dells for everyone!
