2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-27T19:05:40+00:00
    I have the exact same issue. Simplo battery has degraded to only 20% of normal capacity. Oddly it also says it has had 556 cycles which is insane. No way that is true. I would have had to cycle it every day for over a year. Note we usually leave this sp3 in the dock so maybe that is related. I need a fix immediately as the device is almost useless now
    2016-08-27T20:23:08+00:00
    I experience this same issue daily, and now am second-guessing whether or not I should rely on this device for work. Has there been a fix for this yet?
    2016-08-27T20:25:41+00:00
    If you read this thread and other articles, there is one under way.
    Where do we find info on the class action?
    2016-08-27T21:04:30+00:00
    I wonder if "Greg" exists.  Perhaps Greg is a troll and this group has no one at Microsoft who can stand the acid generated by this failure.  Perhaps this group is not monitored at all.
