2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-27T17:46:33+00:00
    anyone interested  in a class action?
    2016-08-27T18:00:09+00:00
    Definitely! Maybe that'll help Microsoft to gain focus on resolving this issue.
    2016-08-27T18:27:06+00:00
    If you read this thread and other articles, there is one under way.
    2016-08-27T18:30:56+00:00
    I'm surprised you stuck with them that long and continued to use them and buy/install their products after so many bad experiences.
