2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-27T14:30:49+00:00
    Thats how mine did.
    2016-08-27T14:39:51+00:00
    Greg - if this is a software update issue, why didn't the technicians who handled my call mention this.  They confirmed to me that it was a hardware failure, but my surface pro is out of warranty and they wanted me to buy another one.  I'm going to a different manufacturer since the surface batteries all seem to fail right after warranty expires.  Disappointing performance by Microsoft.
    2016-08-27T14:53:19+00:00
    This surprises who?
    Microsoft does not care about their mobile computing environment.
    But, I guarantee you, they will always take your money!
    I was one of the 1^st^ 100 users to purchase and original IBM PC with MS DOS 1.0.  Yes, I have been with Microsoft that long!
    Microsoft continues to make me and my business look like a complete fool for recommending and implementing Microsoft solutions.
    The Windows phones become more useless every month.
    I run the Office 365 Admin Tool.  Exchange Online always has problems.
    I have stacks of Surface Pro 3’s that are only good for mouse pads!
    I have tried to reply to this message 6 times now.  On a state of the art desktop, Windows 10 Anniversary Edition, 60mb internet connection.  Microsoft Edge just sits there and spins.  What a useless software solution.
    As I sit here with another $2,000 Surface Pro 3 setup that is functionally useless.
    Greg from Microsoft, please explain to me why I should continue to recommend and implement Microsoft solutions for my business and my clients.
    2016-08-27T15:44:30+00:00
    This surprises who?
    I think you already know why Greg hasn't responded with a reason for you to continue recommending Microsoft products.
