2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-27T14:00:27+00:00
    I read about the battery problem but my Surface is always connected, until yesterday when I went to a meeting and my laptop was on standby but was full charged before hand i.e. 100%. When I opened it to take a photo of a whiteboard, it notified me that I had 10% left! By the time I started the camera app (seconds later), I got notified again that I had 6% left and by the time I pointed the surface towards the whiteboard, my SP3 switched off!!
    Today, I've just turned on my SP that was plugged in all night and it went from 100% to 25% in less than 5 minutes. This is a serious, serious issue Microsoft! I may has well have a desktop if I can only use it when plugged in! I see this issue was reported more than 2 months ago and while you've acknowledge it's a software issue, all well in good, it's still leaves many people with a useless machine unless you're willing to carry your charger every where you go! Can you not provide an exact date as to when this patch will be released???
    My OS build is 14393.82
    Thanks.
    2016-08-27T14:02:26+00:00
    It seems that Microsoft used a bad battery that fails shortly after the warranty period.  Planned obsolescence!
    The battery won't hold a charge so I can't use it if not plugged in.  Microsoft promised to replace my surface for just under $500.  I reluctantly agreed.  They charged my credit card immediately.  They told me they would ship me the new surface and I was to return the old one in the box containing the new one.  Today, I found out that they want my old surface back BEFORE they will ship me the new one!  No regard for all of my files and applications.  What a stupid "policy".  I cancelled the entire order and will go shop for a new PC that ISN'T Microsoft.  Different answers from different agents and Microsoft didn't stand by their product.  Very disappointing.
    2016-08-27T14:06:08+00:00
    Yet another ME TOO!  Microsoft won't stand by the battery.  Seems to me that they have planned obsolence as the battery fails shortly after the warranty period expires.  How clever!  They promised to send me a new surface for $477.  They didn't.  Today, they called and told me that I have to send them my old surface BEFORE they will ship the new one.  What happens to all of my files and applications?  No response!  I cancelled my order and will go buy a non-Microsoft PC this weekend.  What a screwy messed up situation this is with Microsoft.  VERY DISAPPOINTED.  Doesn't seem that they care.
    2016-08-27T14:28:38+00:00
    My Surface Pro 3 is also having battery issues. it shows full charge but when unplugged dies.. this started quickly in July.
    When will the software update be available?
