2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-27T00:55:09+00:00
    Yet another Surface owner with the SIMPLO battery (currently at 144 mWh of capacity).  I purchased my Surface at Costco with an AMEX card.  Just wondered if anyone that did use an American Express card has looked into a warranty claim with them since they are supposed to add a year to the manufacturer warranty period?
    I am in the middle of this.  AMEX does extend for a year, but I am in the middle of the process and do not know if it has been approved.  I called an started a claim and this is what I needed to supply:
    <ul><br><li>AMEX card billing statement showing Cardmember name, account number and transaction charge.</li><li>Charge receipt showing transaction billed to AMEX card.</li><li>Original manufacturer's warranty (complete warranty)</li><li>Itemized repair estimate from a service provider such as the manufacturer, retailer or repair shop</li></ul>
    I didn't have the original warranty, so I pulled it off the internet.  I went into the store and they gave me a quote to replace the out of warranty product for $450.  It might be better to go to a repair shop and get something that says it is not repairable.
    2016-08-27T02:19:22+00:00
    And one more yet to come. Has anybody tried resetting the PC to the original configuration and not updating anything afterwards?
    Yes I tried.
    When I could not run it without plugging it in to AC power, I did a reset to 8.1. The battery status still showed at 85% not charging.
    An upgrade to 10 didn't change anything.
    And now it is not even detected.
    I didn't boot it for the fear of completely bricking it.
    If MS does come up with a patch, that is outside the update cycle, like an installer similar to installers for other peripherals, I may just be able to download it and install it to restore the battery.
    There is a registry tweak suggested earlier which I am contemplating. But how to apply it when my battery is not even detected?
    2016-08-27T03:10:34+00:00
    I was curious also.  Mine shuts off as soon as I get to the login screen now.  Currently I can run the recovery mode options and that's it.  That will stay up and running all day.  Thought about going to a restore point but afraid I'll be stuck as well.  Currently it isn't usable anyway so may be worth it.  I'm not sure how I could even load a firmware upgrade at this point.
    2016-08-27T06:52:03+00:00
    Whats the status on this? I really would like to not have to spend $450 to replace a battery that is impacted by poor software. I need this machine for work, and I need to be mobile to be effective. I feel like SP3 owners are helpless here. This is a high severity issue for those of us impacted.
    Currently, I am at risk of my machine simply powering off if I need to move between meetings on separate floors, which may be a ~5 minute walk.
    I am so disappointed that this has gotten out of hand.
