2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-26T21:19:55+00:00
    Yea, its pretty bad. My SP3 only lasts for a few seconds once I take it off the plug. :(
    2016-08-26T21:30:26+00:00
    Sorry to disappoint the throngs waiting for an actual solution - this is yet another "me too" post. Hoping against hope this will be the one that finally convinces MSFT that this is not an isolated problem and they need to step up or they stand to lose far more than they can absorb with users fleeing to OEMs that at least man up and stand behind their products when they lay an egg.
    SP3 purchased May 2015
    According to Battery Report run on 26 Aug 2016:
    Battery Capacity on 17 May 2015 was 42125 mWh
    Battery Capacity on 22 May 2016 was 41,063 mWh
    Battery Capacity on 25 Aug 2016 was  1,300 mWh
    Where do we sign up for the class action lawsuit??
    Seriously, this is what I want to know. I want to know what my rights are as a consumer and what actions are available for me to take to get some of my losses back from this. Im going into the second week of school and stil have no electronic method for recording or taking notes. This was marketed to replace my laptop, and that is exactly what I have done with it. Now Im left with no alternatives but to wait and save to buy another device, which is going to take a bit of time. Considering the short time I have had this device and the 1400 dollar investment I pumped into it, I should not be facing this many issues. If it were something I had done to the device I would have to take responsibility for it and would be denied any further help, yet they can deny the issue all day and avoid taking fault until more and more people come out, and then they decide to give lip service about how small the affected community actually is and how hard they are working to come up with a solution, blah blah blah. What about the people who spent money to replace the device just to find out it was 450 dollars wasted, or the fact that this issue has likely done permanent damage to the battery's that even after the alleged patch is released many of us will never get back to the battery capacity we should have.
    2016-08-26T22:01:52+00:00
    Yet another Surface owner with the SIMPLO battery (currently at 144 mWh of capacity).  I purchased my Surface at Costco with an AMEX card.  Just wondered if anyone that did use an American Express card has looked into a warranty claim with them since they are supposed to add a year to the manufacturer warranty period?
    2016-08-26T23:07:59+00:00
    Thanks for the update.  I've been having the same issue and have the SIMPLO battery.  As of today, I can no longer get it to boot up though.  It's plugged in, but dies right before/after lock screen.  It's different at different times.  Sometimes I get the repair my PC screen. Either way I cannot get into machine because it dies too quickly.  The closest I've gotten is to the login screen and then it died.  How can I get past this?  I'll need to when the new firmware is available.
