2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
  1. Deleted
    2016-08-26T16:07:59+00:00
    And one more yet to come. Has anybody tried resetting the PC to the original configuration and not updating anything afterwards?
    2016-08-26T16:18:12+00:00
    Already did that with either RTM and Insider`s builds.
    Like I said previously, the update of the software will not affect the firmware. They are probably separated channels on Windows Update.
    Once the firmware is installed/updated, there is no rollback for us. The only way is MSFT to get a newer one and submit either as a standalone installer/flasher or thru regular Windows Update channels.
    Note: once they push it to Windows Update it will take a while until it reach all the server in order to reach all of us - aka no immediate push (if it ever get fixed, I'm kinda hopeless).
    2016-08-26T21:01:42+00:00
    Sorry to disappoint the throngs waiting for an actual solution - this is yet another "me too" post. Hoping against hope this will be the one that finally convinces MSFT that this is not an isolated problem and they need to step up or they stand to lose far more than they can absorb with users fleeing to OEMs that at least man up and stand behind their products when they lay an egg.
    SP3 purchased May 2015
    According to Battery Report run on 26 Aug 2016:
    Battery Capacity on 17 May 2015 was 42125 mWh
    Battery Capacity on 22 May 2016 was 41,063 mWh
    Battery Capacity on 25 Aug 2016 was  1,300 mWh
    Where do we sign up for the class action lawsuit??
