2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-25T16:23:27+00:00
    Why? Its a real issue that hasn't been fixed. If you don't like it then don't open the thread.
    Relax, he said that because many of us are following the thread, expecting a notification about the firmware update, instead of receiving new-comers stories that we all experienced. I have to admit that it is annoying, each times we click on a new comment message in our mailboxes, we hope it is because somebody applied a fresh patch that solve it all, but all we get is new dude's desolation or panic instead.
    However Microsoft are reporting this as a very small minority of users. It may be annoying to find a "Me too" post, but it does acknowledge more people with the issue and the more that log their device, the less of a minority we become and more of an issue it becomes for Microsoft to fix.
    If it is indeed a firmware fix for a bug in a prior firmware release, this would not be a minority, but would affect every single SIMPLO battery owner that allowed Microsoft to update their firmware with a bug.
    2016-08-25T16:56:12+00:00
    True that. We are in a tricky hammer-anvil situation. Despite our annoyance, this is the only way to warn MS about the number of impacted setups.
    You have another good point, there is "small number" and "small number", maybe MS is considering all SP3 with SIMPLO, a small number for them. I don't have any idea about the real number of units dispatched, but the problem looks pretty world-wide from what we see in this thread (Australia, France, Thailand, etc..).
    So yeah, those infos are precious, new-comers must keep posting here.
    2016-08-25T18:01:21+00:00
    Thanks for the reply and for the many threads in this post.
    My SP3 will not boot on the power supply, nor on the dock.
    I have seen comments that it may boot on a SP4 power supply so possibly if I can find a colleague with one that's a possibility.
    2016-08-25T18:54:28+00:00
    Please let us know the outcome
