2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-24T23:02:56+00:00
    More than a month since your post Greg.
    What action? I am now stuck treating my Surface like a desktop because it only lasts about 5 minutes on battery.
    Not good enough.
    J
    2016-08-24T23:05:09+00:00
    I'm not sure if this has been discussed in the thread already (at 64 pages long I could have missed it), but an issue I didn't notice until my SP3's battery capacity fell below 300mWh is that when it is under heavy load (including when it is starting up) it draws more power than the AC adapter can provide and the battery had gotten to the point where it was just barely able to cover the shortfall.
    To avoid reaching a point where the Surface was unable to boot-up, I set the "Maximum processor state" to 65%, which seems to keep the system within the limits of what the AC adapter can provide. This option is not available by default in the Power Options for the Surface. However, adding the registry key below will make the option visible in the advanced power options menu.
    HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\bc5038f7-23e0-4960-96da-33abaf5935ec
    Add: DWORD
    Value Name: Attributes
    Value Data: 2
    My battery status now is No Battery Detected.
    Will this Registry tweak help in that case?
    2016-08-25T00:17:14+00:00
    Of course they do. They own windows and they compile any report they want without your knowledge or consent. They are fully aware.
    2016-08-25T00:21:24+00:00
    I have recently upgraded my 2nd gen i7 Dell laptop to 16GB (although Intel says the chipset won't support more than 8 - guess that's how they wanted you to upgrade) Works like a charm. Also changed HDD to SSD and put in a secondary HDD in the optical bay. Changed thermal paste and cleaned fan. As good as new and battery is still at 50% after 5 years.
