2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-24T19:03:01+00:00
    I don't think we should.
    Microsoft MUST know the number of people affected by this problem otherwise, it will die like many others in this forum.
    2016-08-24T19:08:32+00:00
    Dear Greg,
    All the remarks that have been made in other posts are similar to mine, my Surface-Pro3 is 1,5 year old, battery is dead in 3 minutes after being fully-charged. This is no joke, and not something I expect from a product that I paid €1400,- for. I use the Surface intensively , because of it's "freedom to move around long-time" battery-life.... but this freedom has become an insane obsession for electricity sockets, or walking around with electricity-extension-cables just to get some juice to my Surface Pro, Bro!
    As I find your reply of the solution "*not a hardware issue, but one that can be addressed with a software update."*very hopeful.  I was wondering if you could give me (or all of us) a little estimation on when this software update will be finished and ready to be downloaded! ... nest week / next month / next year
    Hope to read you soon!
    With kind regards
    Peter d B - Netherlands
    2016-08-24T19:51:33+00:00
    Why? Its a real issue that hasn't been fixed. If you don't like it then don't open the thread.
    2016-08-24T20:03:38+00:00
    Relax, he said that because many of us are following the thread, expecting a notification about the firmware update, instead of receiving new-comers stories that we all experienced. I have to admit that it is annoying, each times we click on a new comment message in our mailboxes, we hope it is because somebody applied a fresh patch that solve it all, but all we get is new dude's desolation or panic instead.
