2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-24T10:48:24+00:00
    Microsoft states that while it may not boot while dock, it should boot while
    connected to the power supply only. can you verify that it will not boot while
    not in a dock and connected to the power supply?
    >> Now its finally bricked as it has insufficient juice to even boot
    2016-08-24T11:45:54+00:00
    With respect to the below, with respect to bricked units that won't boot either in the dock or on the SP3 power supplies, please read the prior posts, one by me, that verify that a SP4 charger will reboot a bricked unit and allow modification of the registry that then allows throttling the processor to 65%.  The unit then works on the SP3 power supplies, including the dock.  It will not work without being plugged in.
    It is all in the above posts.
    2016-08-24T14:40:20+00:00
    I've ready every post in this thread.
    Microsoft believes that the afflicted devices should boot with the power supply that is sold WITH the SP3. (No one should need to buy an additional adapter to get to the point of being able to make a regedit.
    If a customer confirms they can't boot with the regular power supply, my intention is to email a contact at Microsoft with this information.
    2016-08-24T17:40:21+00:00
    Hi, after dropping to 144 battery, mine bricked as well. Tried to boot it, nogo.
    So, disconnected keyboard, mouse, and plugged in a secondary display. Somehow this allowed me to boot with the original brick. I use it this way now with bluetooth off and throttled down to a safe level. Will let it sit and wait for the fix for that supposed week.
    There has been some updates that did nothing to the battery problem. On the 23rd.
    Also, noticed when unplugged, battery lasts about 16 seconds. The indicator in the lower right reads 90, 75, 37, percent respectively then the unit dies. But when clicked, the reading is different. Its always close to 15 percent from the get go. Like the information is coming from another calculation.
    Bottom line, I need this thing to work. No one in the right mind would spend 2000 on a 2year tablet. This is a work tool not an iPad for lords sake. If this is not repaired, the 'small number' of users with this issue could contact their local investigative branch of their local news, post reviews online as well as review websites and join the developing class action lawsuit. No company is too big to fail in this competitive market.
    I know its past the warrantee. I know companies make mistakes. The surface is made for microsoft by a gray box manufacturer, things ate bound to happen. Nothingbis without fault. Everybody poops...
    However, its what a company does after to remedy the aituation that counts toward continued patronage...
    M
