2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-24T03:53:33+00:00
    I'd be interested to find out how they expect some of us to apply a fix (should one come) to a machine that won't boot up, due to lack of battery power?
    There are some posts earlier in this thread that suggest a SP4 charger with its higher wattage output can resuscitate bricked SP3s, but that hasn't been verified.  If it doesn't work, an SP4 charger would be an expensive, useless accessory.
    2016-08-24T05:52:50+00:00
    HelloKridsada Thanabulpong,
    Thank you for reaching out to the Surface community. Sorry to hear you are having issues with your battery. If you do in fact have a hardware issue it would be a Warranty/Service related issue that you would have to contact Assisted Support to resolve if you do not have a Microsoft Store in your country. However, to try to determine what is going on with your Surface's battery please follow the troubleshooting steps in this link.
    Please reply with what steps you've tried and what the results were.
    Best Regards
    Really? The support barely know their names and where the start button is...
    2016-08-24T05:59:55+00:00
    My frustration with Microsoft over this wasn't that there was an issue, it was that they weren't communicating to us effectively on the issue. Requiring us to pay $99 to talk to them was even more frustrating, and I eventually filed a report through my state's Consumer Protection Division.  NC has a pretty strong one and they tend to go to bat pretty quickly.
    I was contacted by Global Escalation services last week, who has been working on my case.  I am not going to post the exact contents of the email as I am not sure how much he was supposed to tell me, but here are the things I learned.
    1. This is a software issue (we have been told this)
    2. The patch is in final QA, and is expected within one week
    3. Because the issue has been positively identified as software, the new guidance is to NOT do out of warranty replacements anymore. This guidance has been passed down to the Microsoft Stores. (I assume the previous guidance as to allow out of warranty replacements for very frustrated customers... because this was what the escalation team thought they could do)
    4. He freely admitted frustration with how Microsoft was handling this situation, and that effective communication would have likely gotten in front of this issue. He made it sound like they knew earlier, but couldn't publicly comment on the issue.
    I have agreed to let my case pause for a week to give them time to get the firmware fix out and see if that resolves my issue.
    Hello guys
    I do believe this is a Firmware problem reporting to the OS wrng capacity.
    https://www.microsoft.com/surface/en-us/support/install-update-activate/pro-3-update-history?os=windows-10&=undefined
    The update from System Firmware Update – 7/21/2016 touches the battery firmware and my battery report points that starting there, precisely there, the capacity starts to drop and now I cant keep the device unplugged for more than 5m. I have the surface pro 3, i7 8gb, 256ssd and yes I have the old dock (not this new small box one that was released with surface pro 4).
    Since this is a firmware update there no way to revert it (at least not us) and Microsoft CAN and SHOULD fix it with another firmware update. I saw that there is one released August 1st but that doesn't made any difference. Again, unless you really know it is a battery dead issue, it MUST be fixed by Microsoft with another firmware updare and since its a firmware, you can't uninstall it and doesn't matter if you reset to factory setting(or format it). If there was a driver problem, remove and install an old version would work but that is not the case.
    For the MSFT, Blue Badge and Vendors here specially from the product or the support engineering teams, when are we going to have a formal position about it?
    Its a premium product that cost a lot for most of people and not to mention the marketing made by comparing to macbooks... At least Apple when has a problem with the hardware they exchange in-store for a new not a refurbished even out of warranty if there is a defect on the product without charge!
    I hope this "fix" comes... otherwise more one will be have to sue MS, again...
    2016-08-24T08:42:29+00:00
    hi Greg, I appreciate that Microsoft is saying that's the software issue and it's being worked on atm but if that's the case then it's Microsoft's fault for releasing software that messed it up? and all the users are suffering now? My surface last about 15 mins! on full charge! this is not acceptable. I can only use it as a PC now. I would never have bought it if I new I'd have so many issues with it! when is the estimated date for the quality team to clear the update and release it to the users?
    thanks
    Marcin
