2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-23T16:07:00+00:00
    I have always used windows from 3.1 all versions. Honestly, I don't know what they are trying to achieve with the user interface. Trying to find their way and releasing something not at all intuitive. Why is screen saver located under "lock screen" and screen off and sleep in a totally different place? They still haven't been able to merge settings. Some can be accessed from the sliding in all settings, others from control panel... Auto time zone does not work for me, one needs to disable all those silly services (windows search, superfetch) to improve performance and clean up him- or herself. I removed 20GB+ after the millennial update. And the list goes on with hunting KB articles and forums to find solution to annoying problems. Maybe I'm getting old in my late 30s and not as adventurous as I used to be. I no longer think that fixing these is cool, I just want something that simply works.
    Two positives though so you don't think I'm a permabear. The continuum thing is a really good idea, too bad windows phones have something like 1% market share and the other is that they dare to innovate. Let's be perfectly honest: the SP3 is a really good concept. The touch and pen add a lot to productivity, but hey Microsoft, this is not how you penetrate into a market. A good idea in itself is not enough with so-so execution both on hw and sw front, all topped with horrible customer support.
    From Dale's post above it is clear, that those in decision making have a spine that of a snail and the guy at the end of the food chain is the one showing real empathy and providing presumably unofficial support to manage customers' expactations.
    2016-08-23T16:59:44+00:00
    I think I speak for all SP 3owners when I say, this is the most anticipated day in history and probably the longest week they have ever experienced in their lives.It cannot come soon enough and I hope every single person charged for a replacement descends on Microsoft immediately.
    2016-08-23T17:41:53+00:00
    Yep, I for one can't wait to get back to actually using my SP3. I only hope it then lasts long enough for something worthy to come along as a similar replacement. I don't like Macs all that much, but certainly can't argue with their longevity and build quality. I would love to see their real "Surface-killer" at some point, not just the iPad Pro which is not in the same class. Touch-enabled OSX, a really good KB cover with trackpad, and good battery life...I'd be all for that. However, at least with things like the Asus Transformer 3 Pro it looks like there will be more and more of these type devices to choose from. I love the form factor and don't want to go back to traditional laptop.
    2016-08-23T20:19:52+00:00
    Does anyone know if the two updates today addressed this?
