2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-23T13:43:53+00:00
    Wow, the iFixit teardown looks painful.  Thanks for pointing me to the site.  I hope the fix by MS does not require a battery change...  :).
    I have a very old hard drive (40MB) without a cover, from the early years of computers on display in my bookshelf, so worse case, the SP3 will be a paper weight next to the hard drive.  I will include the price so my grandchildren can have a laugh...
    2016-08-23T13:49:47+00:00
    Someone should write this up and publish on Linkedin, now that MSFT has taken them over...
    Don't know which word describes Miscrosoft's actions better: shady, unprofessional, amateur, dishonest, simply incompetent or what?
    Think I'll just stick with DISGUSTING and will highlight that in my product reviews and personal recommendations.
    2016-08-23T14:53:31+00:00
    I used to be Microsoft and Windows fan, in fact, I even worked for MSFT as an engineer in the past... Last year in March I bought top of the line SP3 for 1.7k $. I thought that thing will last 4-6 years and will be properly supported by MS.
    My battery capacity today is 7,820 mWh, and it halved in two days. It was at 42,583 mWh just a few weeks ago. I hope it doesn't reach the point where I cannot boot it up.
    I also hope Microsoft finally fixes the issue (just 4 months or so after it was reported) and the battery does work again as expected (Li-ion ones degrade only 5-10% per year). I would be beyond angry if my 1.7k$ purchase will be worthless 18 months later.
    This was my last Windows related purchase, all my future computers will be Macs (majority of my computers at home are Macs anyway, just wanted to give the last chance to MS/Windows team/Panos/etc. with my SP3 purchase).
    Windows is so clunky in 2016 compared to everything else - try pairing a bluetooth mouse, merge all 'networks' the OS creates for no good reason to make them 'private' or figuring out why suddenly you can't connect to RDP from work (hint, Windows probably decided that your home network is suddenly a 'new' network and made it 'Public'.. and oh dear, of course you can't connect to RDP port in public because... the protocol, encryption and authentication is... ****?)
    Anyway... so long Microsoft.
    2016-08-23T15:18:16+00:00
    I am pretty sure the bean-counters at MS are likely saying "don't spend MS resources on the problem, the devices are out of warranty", while the folks at MS that do customer support and sales for Surface devices are likely on our side and arguing that they need to find and fix the problem.
