2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-23T02:27:36+00:00
    I would give that a shot, but that is not a Surface Pro3, that's a 4 with a different back.  This is the
    Surface Pro 3 battery degradation vine and u can't open the Pro3 from the back...wish we could.  thanks anyway-
    m
    2016-08-23T11:47:13+00:00
    Hey that Surface Pro 4 video does include removing the screen - it is just not shown in that particular clip. No other way to access the battery. Check ifixit for teardown.
    2016-08-23T12:34:53+00:00
    Is there an ETA on the battery software fix at the moment? School has started and my battery cant even make it through a few notes, yesterday it died before class even began, this is after disabling all non-essential startup app, and all background processes, I've even uninstalled any non-vanilla software from the device making it basically a really expensive word processor, that turns to an even more expensive paper weight when not on a charger. My warranty ran out in April of this year and the battery degradation should not be even remotely this bad for such a new device...
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1167202820
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 7,539 mWh
    CYCLE COUNT 212
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-01-03 - 2016-01-11 40,174 mWh 42,157 mWh
    2016-01-11 - 2016-01-18 40,174 mWh 42,157 mWh
    2016-01-18 - 2016-01-25 40,463 mWh 42,157 mWh
    2016-01-25 - 2016-01-31 40,796 mWh 42,157 mWh
    2016-01-31 - 2016-02-02 40,568 mWh 42,157 mWh
    2016-02-02 - 2016-02-07 40,284 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 40,375 mWh 42,157 mWh
    2016-02-14 - 2016-02-26 40,084 mWh 42,157 mWh
    2016-02-26 - 2016-02-29 40,090 mWh 42,157 mWh
    2016-02-29 - 2016-03-08 40,185 mWh 42,157 mWh
    2016-03-08 - 2016-03-14 40,726 mWh 42,157 mWh
    2016-03-14 - 2016-03-21 40,470 mWh 42,157 mWh
    2016-03-21 - 2016-03-27 40,174 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 40,236 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 40,860 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 40,638 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 40,453 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 40,702 mWh 42,157 mWh
    2016-05-01 - 2016-05-11 42,583 mWh 42,157 mWh
    2016-05-11 - 2016-05-23 42,583 mWh 42,157 mWh
    2016-05-23 - 2016-05-29 37,975 mWh 42,157 mWh
    2016-05-29 - 2016-06-09 39,038 mWh 42,157 mWh
    2016-06-09 - 2016-06-12 35,477 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 35,477 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 29,298 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 29,298 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 29,298 mWh 42,157 mWh
    2016-07-10 - 2016-07-17 29,298 mWh 42,157 mWh
    2016-07-17 - 2016-07-24 29,298 mWh 42,157 mWh
    2016-07-24 - 2016-07-31 24,390 mWh 42,157 mWh
    2016-07-31 - 2016-08-07 15,510 mWh 42,157 mWh
    2016-08-07 - 2016-08-14 12,305 mWh 42,157 mWh
    2016-08-15 11,816 mWh 42,157 mWh
    2016-08-16 10,268 mWh 42,157 mWh
    2016-08-17 10,206 mWh 42,157 mWh
    2016-08-18 9,546 mWh 42,157 mWh
    2016-08-19 9,546 mWh 42,157 mWh
    2016-08-20 9,546 mWh 42,157 mWh
    2016-08-21 9,223 mWh 42,157 mWh
    2016-08-23T13:00:06+00:00
    My frustration with Microsoft over this wasn't that there was an issue, it was that they weren't communicating to us effectively on the issue. Requiring us to pay $99 to talk to them was even more frustrating, and I eventually filed a report through my state's Consumer Protection Division.  NC has a pretty strong one and they tend to go to bat pretty quickly.
    I was contacted by Global Escalation services last week, who has been working on my case.  I am not going to post the exact contents of the email as I am not sure how much he was supposed to tell me, but here are the things I learned.
    1. This is a software issue (we have been told this)
    2. The patch is in final QA, and is expected within one week
    3. Because the issue has been positively identified as software, the new guidance is to NOT do out of warranty replacements anymore. This guidance has been passed down to the Microsoft Stores. (I assume the previous guidance as to allow out of warranty replacements for very frustrated customers... because this was what the escalation team thought they could do)
    4. He freely admitted frustration with how Microsoft was handling this situation, and that effective communication would have likely gotten in front of this issue. He made it sound like they knew earlier, but couldn't publicly comment on the issue.
    I have agreed to let my case pause for a week to give them time to get the firmware fix out and see if that resolves my issue.
