2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-22T20:39:36+00:00
    My SP3 was purchased on 11/27/14, noticed the battery issue in July only because I rarely use the battery since the computer sits on my desk plugged in...  I still get the 99%, Not Charging but it will not boot unless the AC power cord is plugged in.  Best Buy did nothing since the warranty was up.  Geek Squad recommended I take it to the Microsoft Store since I did not have the Geek Squad extended warranty. The Geek Squad does not offer a battery replacement even if you are willing to pay...
    The Microsoft Store agreed to run tests to determine the issues without charge, then they would offer an estimate for the cost to fix the issue.  When I arrived at the MS Store, I was offered an Xbox and 1 game; if I bought an SP4 or I could pay $450 for a refurbished SP3.  I inquired about the warranty that comes with the SP3 refurbished computer and to my surprise, he told me 60 days.  I asked about the purchase of an extended warranty and he said that was not an option.  I explained that I was told over the phone that MS would run tests to determine the issue and provide the estimate to fix the issue.  So MS agreed to run the tests.  They keep my device for 5 days.  I called 3 times but was put off from any diagnosis. On day five, I told them I wanted to pick up my device so they agreed to make the appointment.  We did verify that my charger was not the issue.
    When I arrived, they told me they lost the data and I could pay $1479.00 for them to recover the data and transfer it to another device.  I asked if it was normal to pick up a device in worse condition than when it was dropped off, they said it happens...  (Really........)
    I was able get the device to boot eventually on power and was able to reset the device back to a standard Win 10 install state. I found several batteries for sale between $29 and $129 with a google search...
    I have decided to wait for a fix, before I do any more with my SP3...  It still boots eventually after several attempts and perhaps after saving the BIOS settings and an Auto restore...
    Hope the fix is released while my device will boot...
    2016-08-22T22:11:55+00:00
    Hello everyone,
    Thanks for your patience as we’ve worked though the details here. We can now confirm that this Surface Pro 3 battery capacity question is not a hardware issue, but one that can be addressed with a software update. Our team has been working on, and is now testing, an update that will address this. We’ll publish the update as soon as it has passed our quality assurance process. For now, you should not consider replacing your device as an update is pending.
    Thanks again for your input on this. We appreciate it and we’ll share more when the update is ready.
    Greg
    I'm glad you didn't get canned for actually providing customer service and information. That said, until I see the fix applied, I won't be holding my breath.
    2016-08-22T22:28:24+00:00
    I too have found the batteries on line and bought one.  then watched several utubes & videos on trying to install them.  IT AIN'T HAPPENING!!!  U GOTTA BREAK into the screen to replace them!!!  Than means buy a screen...and who knows what else.
    On another note, I've noticed on a few Surface's for sale on AMAZON, ALL THE REVIEWS ARE FROM 2015.  They won't publish my review and it simply stated ALL batteries are DEAD within 2 years-
    m
    2016-08-23T01:20:27+00:00
    m
    I found a YouTube video for a Surface RT and Surface Pro 4; which showed how to remove the battery from the rear of the case without touching the screen.  A heat gun, a few tools, and some careful determination would get the job done...  But, I will wait for the fix before I invest more $$$.
    I have never tried this, but it seems possible... use at your own risk...
    How to Replace Your Microsoft Surface RT Battery
    YouTube
    · 88,000+ views
    · 1/5/2014
    · HD
    https://www.youtube.com/watch?v=TrDPOkFoyXI (Surface Pro 4 battery Replacement)
    https://www.youtube.com/watch?v=yuW6UhFVwQM  (Surface RT battery Replacement)
