2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-22T18:09:42+00:00
    I went from getting 10 hours of moderate usage (playing videos on youtube) in Windows 8.1 to maybe 2 hours of idle time in Windows 10 at best and about 30 minutes of playing videos on Youtube.  To date, no patch has improved the horrible battery life in Windows 10.
    I believe that the Windows Update bug where it continually runs in the background was never actually fixed, but throttled to use less CPU.  It always seems to be using some CPU, even when it just checked for updates and has no business running anything.
    Shame on Microsoft for not letting me disable automatic updates and update manually, or to give an option to only let windows update run when plugged in!
    2016-08-22T18:30:11+00:00
    Today contacted the defective battery with Microsoft. To not pay $ 99 instead I chose my registered device "Accessories" and escaped charges.
    Sorry but I was told that I had to pay $ 450 because the device is out of warranty. Giving the address to this thread and a detailed description of the problem no reference to this subject.
    Unfortunately, in my case, beyond the problem of the battery I have a problem with a very high overheating of the device.
    No more equipment in this company!
    2016-08-22T18:36:42+00:00
    We can begin to boycott MS continuous reporting this problem through chat. Perhaps in this case, someone will know something more.
    2016-08-22T19:03:07+00:00
    I just received the following message from the support person that I've been talking to at MS...
    I have just received information regarding the potential software fix. We have a software fix for the bug that is currently being tested for a release which should fix the battery. The fix should be out within a week. If you can wait, I would suggest doing so. We will post detailed instructions on how to apply the fix to the support forum at https://aka.ms/sp3battery. Please visit this link next week and keep an eye out for the update.
    Note that the link goes to this forum.
    Unfortunately, as of this morning I can no longer boot my device.  It does not work on the regular power supply nor the dock, and I am loathe to purchase anything at this point (such as the SP4 power cord as suggested in this thread).  I've asked support what I should do and how to get the fix installed on my device since I cannot boot it.  I'll post back when I get a response.
