2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-22T14:20:20+00:00
    My Surface Pro saga has gone from frustration to radioactive.  Friday, I was authorized a replacement.  Took it to the Park Meadows store and after about an hour, they produced a refurb unit from the back.  I was now running late for another appointment, so took it and went.  Got home late that day and guess what - this one has an LG battery but won't boot without a power cord, won't run with the dock power and won't run without the power cord.  Stuck at 54% plugged in not charging.  Spend a good part of Sunday AM chatting with surface support.  They called me around noon and said go to the store to swap it.  Went to the store, swapped.  Verified that it will boot, will charge.  On my merry way.  Screw me, I forgot the most important test - will it boot or run not connected to the wall!  Guess what.  This one too won't do it.  So, now I am back to the store this evening for the 3rd day in a row for my 5th Surface.  I have lost faith in Microsoft building hardware.  We have a long history of this - Zune, Microsoft networking hardware, their fun in the Office Communicator phone with the mirrors, Windows phone.....on it goes.  At what point does the tech press pick up on how bad things have gotten with these devices?  Where is Microsoft with any apologies, any attempt to provide customer service?  I know one of the most critical metrics they track is called DSAT - dissatisfied customers.  One hundred pages of this thread and only 2 responses from Microsoft both saying wait.  This is Lucy holding the ball for Charlie Brown stuff.
    2016-08-22T14:24:45+00:00
    Yes they charge the $99 for online support chat as well.
    2016-08-22T14:33:01+00:00
    Use a proxy extension like Hola! for google chrome and intitate the chat from their Singapore website. See if that works.
    2016-08-22T14:37:49+00:00
    I come from investment banking background handling relationship with US firm's top China client. In that world if you do not live up to your customer's expectations, they will stop trading with you through _all asset classes_ There are many other broker dealers in the street. Luckily for us - there are more and more of these hybrids being released.
