2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-21T18:30:42+00:00
    Just my 2 cents.  I'm waiting for the "software" fix.  My SP3 in in it's dock and has been since the middle of July after I realized how short my battery life had become.  Looking at the batteryrpt, I initially thought that the degradation was only happening during off-charger use, but once I had plotted the capacity vs. time I realized that the capacity was declining even while in the dock on AC!  Note: The graph was plotted with 1-2-3 (I'm old school).![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=eb50a75f-1d28-4fd6-814b-db72ea634b7b)
    Also evident here are two earlier degradations that had mostly recovered until a new degradation started.
    When I try advanced power settings as shown in a previously helpful post, many of the "control features" are missing including those to set the SP3 to 65%.  Is this because I'm on 8.1?  I considered it stupid to upgrade to 10 in the middle of this battery mess.
    2016-08-21T18:50:28+00:00
    An article today from businessinsider.com.  Too bad that he wasn't aware of the experience that hundreds/thousands of us are experiencing.
    http://www.businessinsider.com/microsoft-panos-panay-history-microsoft-surface-2016-8
    2016-08-21T18:52:33+00:00
    Not sure if the registry key is at the exact same location as windows 10 but to enable those power options, you have to run regedit.exe and change the following key value from 0x00000001 (1) to 0x00000000 (0):
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\CsEnabled
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=b67eb7c8-245d-403d-9d81-da11d3f89584)
    Once done, just reboot the Surface Pro 3 and the extra power options should show up in advanced settings.
    HTH
    2016-08-21T22:23:05+00:00
    It can get even more weird:
    My battery capacity (LGC, 20 months old) actually went UP from 42157 to over 44.000mWh (Batteryrpt/BatteryBar/Battery Care) and a displayed wear level of 0%. However, the running time with regular office use (50% Word, 20% Outlook, 30% Firefox with some browsing at 50% display brightness and WLAN) is down to under 2 hours, and when the 10% warning pops up, the unit dies within 3 seconds, too quick to even do a regular hibernation shutdown.
    Microsoft please help!
