2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-21T02:29:50+00:00
    Decided to walk over to the Microsoft store in San Francisco at the Westfield San Francisco Centre mall to try my luck on getting a replacement for my out of warranty SP3 (warranty expired March 1st, 2016).
    I had scheduled an appointment online first, with the issue stated as "SP3 with SIMPLO battery degradation" and included the link to this thread. When I met with the associate, he claimed to not be aware of any official MS memos about the battery issue. I told him that I was no longer able to boot up my laptop, and if it did, it would immediately shut off. I told him I had my SP3 charger, but he started looking around until he pulled out an SP4 charger.
    This made me think he was probably aware of the issue, since the SP4 charger is the only way to make sure the SP3 will turn on and stay on if the battery is completely shot. He clicked around a lot and declared that my battery was indeed dead and that the standard MS replacement would be $450. I replied that I thought it was unreasonable that a laptop would only last 15 months before the battery completely failed. He agreed with me and said, "For your situation, I am going to give you a replacement SP3, however the warranty will no longer be applicable."
    This was the best case scenario I was hoping for, so I was totally ok with this solution. I appreciate that he was willing to replace my SP3 with a refurb unit (LGC battery - I checked before I left the store). I tried to make sure I was friendly and reasonable with my requests for a replacement unit, I'd like to think that helped. Associate was super friendly throughout the interaction and we chatted about lots of other random MS and xbox stuff while we were waiting for the paperwork. All in all, good service and really friendly associate.
    TLDR: Went to SF MS Store. Requested refurb unit and was given one.
    2016-08-21T04:11:58+00:00
    Glad it worked out. Keep checking your battery report, you never know.
    Seems like he acted kind of shady at first though. I hate to believe he was being disingenuous. Why they would they act this way if such a small amount of people are affected is beyond me. My rep said he had attended multiple conf calls where the SIMPLO battery issue was discussed (though he minimized it's scope).
    I'd suggest others point them to Panos and Brian Hall tweets, then this thread.. If still nothing, I'd insist on rescheduling an appointment with someone who has been informed (ie qualified to support the product).
    2016-08-21T06:49:36+00:00
    Hahhhahahaha - I like the part where he demonstrated utmost generosity. MS is taking us for fools buddy. It's something like a conversation in corporate environment with the boss. You know he is BS-ing and he knows that you know, but still have to put up with it... It's kind of sad though, all it would take is to
    1.) apologize big time
    2.) acknowledge (more or less happened)
    3.) ensure swift resolution (either fix or rather exchange given a lot of us have been using our SP3's as desktop for months)
    4.) keep the user base updated to make sure they will remain MS customers in the future
    5.) apologize again
    Most importantly MS do not try to cover up make promises you cannot keep and take your customers for fool in the internet era as it will all blow up into your face.
    This is client servicing 101 and does not take a high corporate title to understand.
    2016-08-21T09:35:44+00:00
    6. Acknowledge that they were working on a fix for an issue while telling people there wasn't an issue.
    1. Admit to telling people it's a hardware fault yet also telling people it's not a hardware fault and it is in fact a software fault.
    2. While telling people it's a software fault, happily charging them an exhberant amount to replace the battery which is apparently not faulty because it's software based.
