2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-20T04:14:26+00:00
    Hello Greg, question related to this. My SP3 has been in this condition now for two to three months. I'm assuming the battery has been in a mostly depleted state as it can't survive off power for even one second. Lithium ion batteries generally degrade much faster if left at full charge or fully depleted. Can we be expecting further battery degradation even with the fix? Should we be seeking replacement regardless of the availability of a software fix?
    2016-08-20T05:17:18+00:00
    We can now confirm that this Surface Pro 3 battery capacity question is not a hardware issue, but one that can be addressed with a software update. Our team has been working on, and is now testing, an update that will address this. We’ll publish the update as soon as it has passed our quality assurance process. For now, you should not consider replacing your device as an update is pending.
    Greg -
    My SP3 has hit the magic capacity level of 144 mWh and now, even when plugged in, will only run for a few minutes before it hibernates. By the time MSFT finishes testing the fix, my SP3 won't be able to stay on long enough to download the software update. Many of us are in that situation now because a fix has taken too long.  Any suggestions for how we are supposed to install the fix?  We can't even take our SP3 to the stores for help because... the MSFT Stores and even Support on Twitter seem to have **NO** idea about this issue or the fact MSFT announced at the end of July that it's a software or firmware issue and not a problem with the battery.
    Is MSFT going to get ALL of their Support Folks and MSFT Store Employees on the exact same message RE:
    * What the problem is with the SP3?
    * Which SP3 users are impacted?
    * How they can help us to fix it the problem - EVEN if our warranty has expired and they won't make us pay $99 to extend the support after the complete run-around we've all gotten?
    I just don't understand why this has been an issue for months and the resolution to this documented matter (even to this day) varies from... you must pay for a replacement... or you must pay $99 to MSFT for help to even talk with you... or the MSFT store employee will talk to you but then tell you there is nothing that can be done [enjoy your new SP3 "doorstop"]... or folks getting refurbished SP3 machines (will these also suffer the battery drain in 12 months down the road)?
    Your CUSTOMERS need your support for a mistake that was made by someone in the food chain.
    2016-08-20T06:40:25+00:00
    Think a lot of users are unaware. Average user may notice that something is not quite right but will definitely not run a powercfg report. What I did was start an online chat with support which was followed by remote assistance. Just be adamant that MS is at fault, which they are and refer back to this growing forum. They are trying to mitigate reputational risk and handle demanding/most disappointed customers in an isolated way. Tweets hold out hope and give themselves an out - and that is referred to **** usually. Not to mention the additional damage the batteries may have suffered in such a state for months.
    As a holder of MSFT shares I find handling this issue outrageous. Will not be stupid to sell as they do well in the cloud biz, but even the biggest apple ipad pro (which MS like to bash in funny commercials) sells better that surface. MS should man up and should start that by looking at client services. You don't have to be a rocket scientist to realize that they are handling it in such an amateur way.
    2016-08-20T09:46:53+00:00
    Yeah, I am asking in forums in Singapore and doesn't seem anyone have this problem, or no one bother to reply me there. Is yours SIMPLO batteries? If yours is still under warranty, have you tried contacting to Microsoft yet for replacement?
    My SP3 is out of warranty and can't even detect a battery. I didn't try contacting MS Singapore phone support yet. Earlier the SP3 was showing battery status as plugged in not charging. Then I tried a ticket for repair but it was asking me to pay SGD 790 for a replacement which I obviously rejected. In the same page it suggested a reset which I did, got 8.1 with no battery detected and this status of no detection stayed after I updated to 10. Only then I came across this forum through Verge.
    How to find the battery model now? Any print on the slate or the box to show it?
    Thanks.
