2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T20:00:03+00:00
    I agree, Greg's update is largely the same as the earlier one weeks ago.  No real substance. We'd like actual, usable information with a date where there is commitment a functional fix or a free replace our SP3's will be provided.  this is crazy.
    Chuck
    2016-08-19T21:13:27+00:00
    Ya'll  have a right to be upset..  BUT ... sometimes it takes time to identify, remediate, test and deliver a fix.
    So Greg doesn't get thrown under the bus.. you all can go to TWITTER  and see that Panos Panay himself tweeted the fix is close and is a SOFTWARE fix...
    Likely this issue is with the interaction between the system firmware and how it reports and reads the battery level during charging.  So I would expect the fix would yes return the battery to full capacity as it would both properly report the battery level AND initiate charging properly based on the correct level.
    Sorry you all have had SP3 issues I am in IT and we buy lots of SP's (3's and now 4's) and have very few with this issue.
    Regards,
  3. Deleted
    2016-08-19T23:00:39+00:00
    Success!!!  No, not with the battery, but with support processing a replacement ticket for me.  I did the online support chat, connected with a tech, provided him the battery report and explained that it no longer would run on the Surface dock, only with the power cord.  He processed the service request.  I go to the local Microsoft store - Park Meadows here in Colorado - and should be handed a replacement device tomorrow.  I'll post an update if this happens as seamlessly as it appears to be headed.  In the mean time, I'm buying a lotto ticket on the way home.
    Eric
    I hope this worked for you.  I went into the Park Meadows store today (my second trip) and they refused to do anything.  The most they would do is print up and estimate to "fix" (trade for a refurbished machine) so I can submit something for an extended warranty claim through my AMEX.
    The guy I talked to was really nice, but didn't seem to have an issue with the unit lasting 18 months.
