2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T19:16:05+00:00
    Greg,
    I'd be interested to know how you can address this with an update if the surface is essentially dead because there is just about no battery life left.
    Have you got some kind of super quick update via usb that can bootstrap the fix within the minute that my Surface stays alive? ..because certainly the machine will not stay up long enough to download and install any kind of update the usual way.
    2016-08-19T19:29:45+00:00
    Read my reply regarding using the Surface Pro 4 15 volt power supply above.
    Mine was completely bricked.  Using the 15 volt supply, I brought it back long enough to do the other two fixes suggested by others.  Now I can use it attached to the dock, albeit slow and hardwired, useless for my purposes.
    Greg,
    2016-08-19T19:41:27+00:00
    Greg,
    Good information, but "buy a new power supply" can't be an acceptable part of the solution they roll out.
    2016-08-19T19:58:00+00:00
    Just getting mad at how some ripped 450$ by their local nuts store deny the possibility of a SW fix, simply because they paid...
    Just open your mouth if the next patch does nothing but don't start to cry and discourage others because local stores ripped your bucks!?
    Like "when I am gone let happen what may..."...
    Or like "no, you won't get your fix because I paid !"
