2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T17:29:36+00:00
    Hi Greg, Superb news! thank you.
    If you are looking for beta testers then count me in!
    Dave
  2. Deleted
  3. Deleted
    2016-08-19T17:42:32+00:00
    So for those of us who have suffered extreme battery degradation (mine is 144mWh), will the software update return the capacity to original levels?  Will we even be able to install the update?
