2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T17:07:36+00:00
    pleased to hear this. Thank you for the update.
    Sev
    2016-08-19T17:16:31+00:00
    Can you please make sure that the right people hear that those of us who paid out of pocket for this repair should have some compensation? I paid the $450 way back in April before Microsoft acknowledged this issue.
    2016-08-19T17:17:08+00:00
    Hi Greg,
    This couldn't have come at a better time, thank you!
    May I recommend a less scattershot approach to communicating with the end users that what we've experienced here and in other venues? Chat support, Store support, phone support, Twitter, all seem to have different and often times contradicting information.
    For now, obviously you folks need to focus on delivering the fix. However, post that I sincerely hope that there's a post-mortem of this case study in poor communication within MSFT, and lessons are learned.
    2016-08-19T17:19:57+00:00
    Of course, this will be welcome news when the update is provided. And I think we all understand that you are not prepared to commit to a specific and firm date. But I am sure you can also understand our frustration under these circumstances and a bit more transparency would cost you nothing and would be so greatly appreciated by your customer base.
    Is this something that will likely happen in a matter or days or weeks or months? We are not the enemy and do not want to be. We just want to be treated like good paying customers who merit some respect. Please provide just that little bit more of helpful information.
    Thank you.
