2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T14:29:30+00:00
    I sure will!
    2016-08-19T15:32:12+00:00
    IT_Michigander, where did you email them? I don't want to pay the $99 to get support as I don't need support, I need an answer.
    thx
    Sev
    2016-08-19T15:44:47+00:00
    I went through here:
    https://www.microsoft.com/surface/en-us/support
    In the lower right hand side, there is a talk to a live agent.  Give that a try.
    2016-08-19T17:02:56+00:00
    Hello everyone,
    Thanks for your patience as we’ve worked though the details here. We can now confirm that this Surface Pro 3 battery capacity question is not a hardware issue, but one that can be addressed with a software update. Our team has been working on, and is now testing, an update that will address this. We’ll publish the update as soon as it has passed our quality assurance process. For now, you should not consider replacing your device as an update is pending.
    Thanks again for your input on this. We appreciate it and we’ll share more when the update is ready.
    Greg
