2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T14:04:14+00:00
    Success!!!  No, not with the battery, but with support processing a replacement ticket for me.  I did the online support chat, connected with a tech, provided him the battery report and explained that it no longer would run on the Surface dock, only with the power cord.  He processed the service request.  I go to the local Microsoft store - Park Meadows here in Colorado - and should be handed a replacement device tomorrow.  I'll post an update if this happens as seamlessly as it appears to be headed.  In the mean time, I'm buying a lotto ticket on the way home.
    Eric
    2016-08-19T14:12:30+00:00
    Congrats Eric!  Were you outside the original warranty?
    2016-08-19T14:19:07+00:00
    After u get the replacement, can u share with us the new battery model and whether still suffers battery degradation?
    2016-08-19T14:21:37+00:00
    I believe so.  The unit I have is a replacement for one that no longer would charge.  Keeping my fingers crossed for tomorrow and a unit that has an LG battery.
