2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T08:32:23+00:00
    Ok, today's been my second attempt at MS support. The first one was before it became such a long thread here. First chat concluded that my settings/software are fine and it was indeed a battery problem (no word of software fix back then) and servicing would be around 7-800 SGD. Out of warranty. Let me not quote my thoughts from back then.
    Second chat with support happened today and I referenced to this forum right away. A series of mandatory checklist items via remote assistance concluded that my unit is indeed affected and they said that a replacement can be issued. At a charge of about SGD 160 to which I said no again as it is clear that MS is at fault. By right they should issue a recall and fix those units free of charge regardless of warranty status. Especially if it's a software issue as they say. And that problem was not present until the 12th month of warranty. They caused the issue and not the user for many of whom battery degradation goes unnoticed until it's too late. My waiver request has been forwarded to some internal team and will hear back from them on Monday. A lot more professional way of handling the issue, but I guess that has to do with much bigger publicity of the problem by now. Can share my chat log on request.
    2016-08-19T08:50:49+00:00
    Looking at the currency, it seems like you are from Singapore. Can I know what model battery are you using and what have the battery degraded to?
    2016-08-19T09:22:22+00:00
    Unit bought in SG, but staying in Thailand since the beginning of this year. They quoted THB 4200+tax for replacement. SP3 model: i5, 8GB ram, 256GB SSD. Battery is SIMPLO, 100% wear, actual capacity is 144 mWh out of design capacity 42,000.
    2016-08-19T12:04:11+00:00
    Just need to have a rant and I know people here will understand and feel my pain.
    Installing upgrade to SQL Server Management Studio on my SP3, you know so I can get work done, and yes you guessed it the machine started leaning on the battery and promptly hibernated! Stupid useless piece of crap!
    Thanks for listening.  Microsoft you can shove my SP3 up your ...
