2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-19T01:28:56+00:00
    I used to love my Surface Pro 3... until May 2016. That is when issue started. At first I'd go from 100% to low battery in <2 hours. Then it was within a few minutes... now it won't even last 1 minute.  Here is what I've tired with no success:
    * Cleaned the charger contacts.
    * Made sure the charger light was on.
    * Made sure I had all of the latest software updates: Settings>Updates&Security>Check for Updates
    * Installed latest Firmware updates (latest was Aug 1, 2016) and confirmed it successfully installed: Settings>Updates&Security>Update History
    * Restarted Surface Pro 3.
    * Shut down the Surface Pro  and then let it charge for over an hour. Turned it back on.
    * Did a Two-Button shutdown: With surface on... Hold power button for 30 seconds & release it. Hold down the power button & volume up button at same time for 15 seconds & release it.  Waited 30 seconds and then restarted Surface Pro 3.
    * I also ran the battery report.  I have the battery that everyone has been complaining about - SIMPLO.
          At 07:38:36... I was at 100% battery and I unplugged the charger
          At 07:38:50... I was at 90% battery capacity remaining
          At 07:38:52... I was at 6% battery capacity remaining.
    So my I can run on battery for SIXTEEN SECONDS.   Seriously?!
    NOTHING has fixed the issue.  I have a Surface Pro 3 that can ONLY be used if it's plugged into the wall.  Kinda defeats the purpose of why I bought this machine.  Started in May and I'm sitting here in August with an unusable PORTABLE device!!
    When will MSFT have a fix?  Since I'm not the only one with this issue I'm NOT paying for a fix!!  My business will simply go elsewhere.
    2016-08-19T04:55:46+00:00
    I've been having a discussion with Barb Bowman on twitter around the SP3's that are so low on capacity that they no longer function when docked.  Are there SP3 owners on this topic that are also finding that the SP3, when at it's lowest capacity, is also unable to stay on even using the supplied power supply?  I'm sure some people said that was the case but we want to be sure.
    Yes!  This just started happening with mine this week.  Battery drain issue began in May 2016, but now even plugged in I can only get a few minutes of work before it shuts down. This was my latest battery report from Aug 15.
    What began as a great portable device, became a "desktop" always tethered to the wall, and now to something completely unusable even plugged in. I'm going to have to replace it before MSFT finds a fix - if they are even really working on it. Guaranteed the replacement will be a non-MSFT product after this entire support Bull Sh*t.  I have never seen anything handled this poorly. Shame on you, Microsoft!
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=381b7600-1b14-4575-a2d8-06f9fdb697bd)
    2016-08-19T06:30:03+00:00
    It doesn't help that essentially Microsoft are not getting any negative press about this which I suspect is because it is the previous generation and so the ones likely to report it are now using a Surface Pro 4 and so aren't feeling the pain directly.  The amount of negative coverage around the Surface Pro 4 and Surface Book was very high because the press were actively using them.
    Sadly this is not the first failure by Microsoft with the Surface brand given the Surface Pro 2 had firmware released that stopped it charging and Microsoft thought it was ok to leave it that way over the Christmas holiday period (although they did have a change of heart following some negative press).  This was followed by the wall of silence surrounding the SP4/Book firmware issues relating to power management but because those were new devices the levels of negative press forced them into action.
    Sadly I feel we are a low priority with the team focused on the Surface Pro 5, Surface Book 2 and a possible Surface Phone.  The question is will they have any customers left who would trust them enough to purchase one as I suspect each will have their own set of launch issues.  The Surface team talk about their passion for engineering excellence but the reality is they just don't have the experience of a long term OEM like HP, Dell, Lenovo, etc.
    This has taught me one thing though and that is my work device must have a user replaceable battery and that a tablet should be just that and not some fancy 2-in-1 device.  Better to get a device that has been designed and built to be good at one thing not just alright at two things.
    2016-08-19T07:41:37+00:00
    Hear hear.
    I was thinking about replacing my SP3 with a surface book in a couple of years time. Seems I will be replacing it sooner with something not made by Microsoft. I 'replaced' my iPad 2 with a sp3 and so far, the iPad 2 is looking like it will outlive it's replacement. I will most likely be going down the multiple device route, I cant say the sp3 does tablet or pc as well as it should. I left apple because I was tired of their new kiddy style simple route. I'm going to go back because I want something that works. Seems apples old line ' it Just works' sort of fits now, because compared to microsoft devices, a 2e would be better right about now.
