2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T23:17:00+00:00
    My first replacement had an LG battery with zero charges, but a deffective fan.  I returned that for another with the LG battery and zero charge cycles.
    2016-08-18T23:20:09+00:00
    LGC batteries are also affected although far fewer reports than for SIMPLO so you might be ok.
    Yep, and I've heard some LGC complaints but I wasn't sure what to make of it at this point. I don't think MS has excluded LGC in any of their statements so it's possible LGC's were just manufactured later and therefore will be impacted later.
    My LGC capacity has already declined (goes up and down actually). My only saving grace is that they extended my warranty another year+2mo (Oct 2017). So I'll be running my powercfg frequently.. Still kinda sad that you'd have to.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=40c7798d-8eda-486e-b560-2389817fed97)
    My LGC battery have 28,000mWh of capacity from 42,000mWh. That was a high jump in just a few weeks. If you want to check your battery degradation without running powercfg i suggest you download the FREE version of BatteryBar. It will show your battery status next to your clock in the taskbar.
    2016-08-18T23:22:25+00:00
    First off, let me report that I have had to replace my bricked SP3 with a Samsung Notebook 9. But ...
    I bought one of the 15 volt Surface 4 power supplies mentioned and was able to unbrick my Surface long enough to change the registry allowing for adjusting the processor state to 65% as stated by the INCREDIBLY helpful poster above. I can now operate my SP3 docked and get my lost material off the otherwise useless machine.
    Recommended.
    I'm not sure I want to leave my Surface on the 15 volt supply (rather than the SP3's 12 volt) and will probably not do that. But a BRAVO!!! to the persons here who recommended the 15 volt SP4 supply and a BRAVO!!! to the person giving the registry key to allow throttling the processor. Thank you both.
    There are some pretty smart people contributing here!
    Steve
    Those 2 tips were really helpful.
    2016-08-19T00:08:56+00:00
    I completely understand that, i was explaining that the microsoft supporter person I spoke with, when questioned, explained that my replacement surface would not have any warranty past the date of my original device's warranty. He did not mention the 90 days. I in fact raised issue and he said that was how it was. When i checked my account however, the extension in the warranty does show.
    I may be using that warranty, after seeing that my replacement unit's battery capacity has gone down 2000mAh after one day.
    I am not pleased.
    just to add, I have just got off chat with Ms and they told me my warranty had been extended for my new device until November 2017!!!
    That's great news. Similar to my experience.
    Not to sound cynical but I would encourage you to check their work - If you haven't, go to the surface support site, register your replacement surface and review the warranty expiration date. First thing I did when I got mine replaced.
