2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T21:41:29+00:00
    Oops sorry, I missed that you asked that. Yes it does :(
    2016-08-18T21:47:59+00:00
    Good news,MS close to fix battery problem
    https://mobile.twitter.com/IsForAt/status/765588990288429056
    2016-08-18T22:17:25+00:00
    No new insights to contribute - just wanted to add my name to the ever-growing list of users with issues. Battery currently still usable unlike many others, but dropping faster than I would like despite my attempts to never use on battery only recently.
    Hoping the promised fix arrives soon!!
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=75a4995e-3357-4f7c-9c7b-3a24bbbbaa84)
    2016-08-18T22:52:02+00:00
    First off, let me report that I have had to replace my bricked SP3 with a Samsung Notebook 9. But ...
    I bought one of the 15 volt Surface 4 power supplies mentioned and was able to unbrick my Surface long enough to change the registry allowing for adjusting the processor state to 65% as stated by the INCREDIBLY helpful poster above. I can now operate my SP3 docked and get my lost material off the otherwise useless machine.
    Recommended.
    I'm not sure I want to leave my Surface on the 15 volt supply (rather than the SP3's 12 volt) and will probably not do that. But a BRAVO!!! to the persons here who recommended the 15 volt SP4 supply and a BRAVO!!! to the person giving the registry key to allow throttling the processor. Thank you both.
    There are some pretty smart people contributing here!
    Steve
