2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T17:09:39+00:00
    So I think I inadvertently bypassed the system a bit and avoided the $99.  I accidentally called the consumer line instead of business, so they took down my info and said the business folks would give me a call.  I missed the call so they sent an email instead, which started an email chain.  They haven't said anything about money yet, so fingers crossed!
    2016-08-18T17:21:32+00:00
    KaneHughes it's actually both according to the terms of sale. If your machine had to be exchanged - let's say - on month 3 of a 12 month warranty, then the refurb would carry forward the reminder of 9 month warranty. If however you had to exchange on month 11, then the refurb would have 90 days warranty which would be 2 months beyond the original warranty. This is my understanding based on the warranty terms. I'm not employed by MSFT though, so get a confirmation!
    2016-08-18T17:37:08+00:00
    I have the same problem. When will we be able to have a follow up on that correction Microsoft is working on? I am a college professor in Marketing and the battery problem on my Surface Pro 3 has an impact on my work. I bought this product as my main work tool.  It is really frustrating. I feel very much helpless and do not find that Microsoft is giving the support they should in the situation (hence no guaranty, no service while the problem is in the machine that you have conceived) and not taking the responsibility of your product. At lease, acknowledge the problem to us Surface Pro 3 owners and keep us informed. That is the basics of good marketing strategy to make sure the experience of the client is positive when he byes the product and after. Then, the client keeps a positive opinion of your company and even more so when you treat your clients well when they have a problem. I hope you can correct the problem quickly. PLEASE KEEP US INFORMED :-(
    2016-08-18T18:21:30+00:00
    For those who have exchanged (either with a fee or not)...aren't you concerned you are getting a refurb that will have the same issue?
    I expressed those concerns during my replacement at the store and they were happy to turn it on and verify the battery was not a SIMPLO before sending me off with that unit.
