2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T15:22:36+00:00
    That's wonderful news!  How did you get to that point so that I may follow suit?
    2016-08-18T15:36:48+00:00
    I had originally contacted Microsoft before stumbling across this thread, at which point they had said that it would be $450 for the replacement (2 months out of warranty).  After finding this thread, I replied and said:
    "It has become apparent that this battery failure is due to a manufacturing fault with the Simplo batteries, as evidenced by this thread:
    http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfhardware/surface-pro-3-battery-degradation/783f6a00-19ba-4dcf-a828-0ad87751e15a
    This is obviously an egregious manufacturing error.  There is no way that I will pay $450 to fix Microsoft’s mistake.  How can I go about getting this resolved?
    Thanks,"
    That's when they replied with the message posted previously.
    Obviously, results may vary.  I just happened to have an excellent support rep.
    2016-08-18T15:38:02+00:00
    Surface Pro 3 is little over 1 year old and battery holds no charge. As soon as power is removed from the Surface Pro 3 it will shut down cold.   The battery is an X898289 from Simplo.  The design capacity is 42,157 but the full charge capacity is reporting 144mWh and a cycle count of 74.
    We will refuse to pay Microsoft $450 for the privilege of fixing this computer since both phone techs and in-store techs will not acknowledge that the battery (or firmware related to the battery) is a possible problem.  If firmware is the issue Microsoft needs to release update quickly or offer either battery replacement or full device replacement.  Right now the functionality of the Surface is significantly reduced. I will not order new Surface devices for clients until issue is resolved so I can confidently recommend.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=d4e649d4-7417-4402-9c79-cbe4ad077df1)
    2016-08-18T15:46:25+00:00
    What was the method used to contact Microsoft Support?
    Other than travelling for hours to get in person to a Microsoft store for Free troubleshooting, the only options I've found to contact Surface support involve paying $99 just to talk to someone. I presume you didn't pay for access?
    eg: This appears to demand payment for anything out of warranty that involves talking to a human: https://www.microsoft.com/surface/en-ca/support/contact-us
    Thanks for your help and glad you had a good experience where so many others have not.
