2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-17T15:36:44+00:00
    Here's mine...even further gone. An this the second battery. First one was "battery not detected" on a nearly new unit unit replaced under warranty.  This the replacement about 16 months old now, but you an see it starting to fail near the en of February, 2016.
    Steve
    Battery report
    COMPUTER NAME SCS-SP3
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.306.amd64fre.th2_release_sec.160422-1850
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-06-15 12:20:46
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163663876
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 790 mWh
    CYCLE COUNT 139
    Recent usage
    Power states over the last 3 days
    2016-06-12 12:26:00 Connected standby AC 100 % 1,277 mWh
    12:55:23 Active AC 100 % 1,277 mWh
    13:10:56 Connected standby AC 100 % 1,277 mWh
    13:14:54 Active AC 100 % 1,277 mWh
    13:38:39 Connected standby AC 100 % 1,277 mWh
    13:38:40 Suspended 100 % 1,277 mWh
    2016-06-13 03:00:22 Active AC 68 % 616 mWh
    03:18:06 Connected standby AC 100 % 912 mWh
    03:32:20 Active AC 100 % 912 mWh
    04:17:40 Connected standby AC 100 % 912 mWh
    13:21:13 Active AC 100 % 912 mWh
    13:53:04 Connected standby AC 100 % 912 mWh
    13:57:20 Active AC 100 % 912 mWh
    14:53:26 Connected standby AC 100 % 912 mWh
    2016-06-14 00:05:54 Active AC 100 % 912 mWh
    00:34:45 Connected standby AC 100 % 912 mWh
    00:34:45 Suspended 100 % 912 mWh
    17:02:55 Active AC 100 % 790 mWh
    17:43:46 Connected standby AC 100 % 790 mWh
    2016-06-15 09:19:41 Active AC 100 % 790 mWh
    09:37:50 Connected standby AC 100 % 790 mWh
    11:22:17 Active AC 100 % 790 mWh
    12:11:01 Connected standby AC 100 % 790 mWh
    12:13:45 Active AC 100 % 790 mWh
    12:19:00 Report generated AC 100 % 790 mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    2015-12-07 - 2015-12-14 0:54:46 25:33:29 4:14:57 130:41:03
    2015-12-14 - 2015-12-21 0:06:24 6:33:05 0:49:03 83:17:56
    2015-12-21 - 2015-12-28 1:09:55 42:05:49 6:56:18 42:45:48
    2015-12-28 - 2016-01-04 0:00:27 171:10:53 - -
    2016-01-04 - 2016-01-12 0:00:47 0:00:01 3:56:56 31:07:02
    2016-01-12 - 2016-01-18 0:21:17 130:39:40 0:01:07 0:00:03
    2016-01-18 - 2016-01-25 0:00:28 58:10:50 3:54:42 33:00:18
    2016-01-25 - 2016-02-02 0:42:56 3:15:10 5:32:18 111:30:32
    2016-02-02 - 2016-02-08 0:42:06 5:03:47 5:54:27 100:35:52
    2016-02-08 - 2016-02-15 0:39:48 21:14:32 7:23:59 110:23:27
    2016-02-15 - 2016-02-22 1:12:36 5:41:48 6:57:26 25:11:38
    2016-02-22 - 2016-02-29 3:01:21 90:01:49 6:05:21 63:48:27
    2016-02-29 - 2016-03-07 0:24:06 0:09:02 24:54:27 85:55:23
    2016-03-07 - 2016-03-14 2:07:11 10:18:49 10:55:39 103:36:54
    2016-03-14 - 2016-03-28 4:04:52 12:24:57 20:44:58 216:05:32
    2016-03-28 - 2016-04-04 2:15:49 6:20:30 8:34:11 123:12:51
    2016-04-04 - 2016-04-11 0:04:27 104:39:36 0:58:51 32:45:20
    2016-04-11 - 2016-04-18 - - 2:13:23 9:20:29
    2016-04-18 - 2016-04-25 - - 1:01:43 43:36:25
    2016-04-25 - 2016-05-02 0:47:23 0:23:41 1:28:00 58:56:25
    2016-05-02 - 2016-05-09 0:00:04 - 5:31:31 75:00:03
    2016-05-09 - 2016-05-16 3:05:19 0:09:53 5:05:14 136:03:32
    2016-05-16 - 2016-05-23 0:22:54 13:24:47 3:45:58 135:36:41
    2016-05-23 - 2016-05-30 0:44:02 0:05:55 4:18:22 104:09:46
    2016-05-30 - 2016-06-06 0:16:52 - 11:32:28 112:36:44
    2016-06-07 0:01:49 - 0:26:22 -
    2016-06-08 0:00:18 - 0:51:40 0:58:47
    2016-06-09 0:00:40 - 1:41:36 11:20:28
    2016-06-10 - - 1:20:56 4:51:45
    2016-06-11 - - 3:47:18 20:12:15
    2016-06-12 - - 1:22:46 12:15:39
    2016-06-13 - - 2:30:58 18:28:17
    2016-06-14 - - 1:09:39 6:22:01
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-12-07 - 2015-12-14 40,523 mWh 42,157 mWh
    2015-12-14 - 2015-12-21 40,152 mWh 42,157 mWh
    2015-12-21 - 2015-12-28 40,425 mWh 42,157 mWh
    2015-12-28 - 2016-01-04 40,941 mWh 42,157 mWh
    2016-01-04 - 2016-01-12 41,003 mWh 42,157 mWh
    2016-01-12 - 2016-01-18 41,063 mWh 42,157 mWh
    2016-01-18 - 2016-01-25 41,063 mWh 42,157 mWh
    2016-01-25 - 2016-02-02 40,574 mWh 42,157 mWh
    2016-02-02 - 2016-02-08 40,956 mWh 42,157 mWh
    2016-02-08 - 2016-02-15 42,194 mWh 42,157 mWh
    2016-02-15 - 2016-02-22 42,583 mWh 42,157 mWh
    2016-02-22 - 2016-02-29 42,583 mWh 42,157 mWh
    2016-02-29 - 2016-03-07 40,864 mWh 42,157 mWh
    2016-03-07 - 2016-03-14 36,580 mWh 42,157 mWh
    2016-03-14 - 2016-03-28 31,270 mWh 42,157 mWh
    2016-03-28 - 2016-04-04 25,919 mWh 42,157 mWh
    2016-04-04 - 2016-04-11 22,764 mWh 42,157 mWh
    2016-04-11 - 2016-04-18 20,794 mWh 42,157 mWh
    2016-04-18 - 2016-04-25 20,257 mWh 42,157 mWh
    2016-04-25 - 2016-05-02 19,065 mWh 42,157 mWh
    2016-05-02 - 2016-05-09 17,183 mWh 42,157 mWh
    2016-05-09 - 2016-05-16 13,618 mWh 42,157 mWh
    2016-05-16 - 2016-05-23 10,775 mWh 42,157 mWh
    2016-05-23 - 2016-05-30 6,568 mWh 42,157 mWh
    2016-05-30 - 2016-06-06 3,787 mWh 42,157 mWh
    2016-06-07 2,054 mWh 42,157 mWh
    2016-06-08 1,826 mWh 42,157 mWh
    2016-06-09 1,710 mWh 42,157 mWh
    2016-06-10 1,597 mWh 42,157 mWh
    2016-06-11 1,277 mWh 42,157 mWh
    2016-06-12 1,277 mWh 42,157 mWh
    2016-06-13 957 mWh 42,157 mWh
    2016-06-14 876 mWh 42,157 mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2015-12-07 - 2015-12-14 6:35:06 108:51:34<br><br>15 % / 16 h 6:51:02 113:14:56<br><br>14 % / 16 h
    2015-12-14 - 2015-12-21 4:49:03 10:17:52<br><br>155 % / 16 h 5:03:29 10:48:43<br><br>148 % / 16 h
    2015-12-21 - 2015-12-28 4:25:12 92:13:36<br><br>17 % / 16 h 4:36:34 96:10:41<br><br>17 % / 16 h
    2015-12-28 - 2016-01-04 2:22:49 368:16:42<br><br>4 % / 16 h 2:27:03 379:13:00<br><br>4 % / 16 h
    2016-01-04 - 2016-01-12 - - - -
    2016-01-12 - 2016-01-18 3:40:18 231:27:50<br><br>7 % / 16 h 3:46:10 237:37:50<br><br>7 % / 16 h
    2016-01-18 - 2016-01-25 13:53:09 207:54:27<br><br>8 % / 16 h 14:15:21 213:26:48<br><br>7 % / 16 h
    2016-01-25 - 2016-02-02 2:54:02 - 3:00:49 -
    2016-02-02 - 2016-02-08 6:48:46 317:04:04<br><br>5 % / 16 h 7:00:46 326:21:56<br><br>5 % / 16 h
    2016-02-08 - 2016-02-15 5:19:48 226:20:13<br><br>7 % / 16 h 5:19:31 226:08:18<br><br>7 % / 16 h
    2016-02-15 - 2016-02-22 6:19:47 50:20:18<br><br>32 % / 16 h 6:15:59 49:50:05<br><br>32 % / 16 h
    2016-02-22 - 2016-02-29 11:23:45 233:58:47<br><br>7 % / 16 h 11:16:55 231:38:20<br><br>7 % / 16 h
    2016-02-29 - 2016-03-07 2:29:17 17:14:00<br><br>93 % / 16 h 2:34:00 17:46:43<br><br>90 % / 16 h
    2016-03-07 - 2016-03-14 2:33:20 11:05:08<br><br>144 % / 16 h 2:56:43 12:46:33<br><br>125 % / 16 h
    2016-03-14 - 2016-03-28 3:09:43 40:53:52<br><br>39 % / 16 h 4:15:46 55:08:12<br><br>29 % / 16 h
    2016-03-28 - 2016-04-04 4:40:33 43:57:39<br><br>36 % / 16 h 7:36:20 71:30:06<br><br>22 % / 16 h
    2016-04-04 - 2016-04-11 - 111:57:31<br><br>14 % / 16 h - 207:20:16<br><br>8 % / 16 h
    2016-04-11 - 2016-04-18 - - - -
    2016-04-18 - 2016-04-25 - - - -
    2016-04-25 - 2016-05-02 2:20:29 17:42:24<br><br>90 % / 16 h 5:10:39 39:09:13<br><br>41 % / 16 h
    2016-05-02 - 2016-05-09 - - - -
    2016-05-09 - 2016-05-16 2:42:08 20:57:51<br><br>76 % / 16 h 8:21:57 64:53:56<br><br>25 % / 16 h
    2016-05-16 - 2016-05-23 1:37:29 68:39:29<br><br>23 % / 16 h 6:21:25 268:37:27<br><br>6 % / 16 h
    2016-05-23 - 2016-05-30 1:18:36 12:13:13<br><br>131 % / 16 h 8:24:34 78:26:12<br><br>20 % / 16 h
    2016-05-30 - 2016-06-06 0:26:30 - 4:55:02 -
    2016-06-07 0:28:55 - 9:53:41 -
    2016-06-08 - - - -
    2016-06-09 0:01:37 - 0:40:12 -
    2016-06-10 - - - -
    2016-06-11 - - - -
    2016-06-12 - - - -
    2016-06-13 - - - -
    2016-06-14 - - - -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 0:06:02 2:43:53<br><br>586 % / 16 h 5:22:34 145:45:23<br><br>11 % / 16 h
    2016-07-17T21:51:43+00:00
    Anybody else find that once the battery was below 1000mwh they could not use the SP3 even docked because once the CPU and fan got going the device would shut off?
    Also - my device was docked most of the time - is this the same for everyone else?
    2016-07-17T23:08:33+00:00
    I bought my surface 5/23/15 and loved it up until a few days ago.  Funny how these batteries fold up just after the warranty expires.
    COMPUTER NAME SURFACEPRO3
    OS BUILD 9600.18378.amd64fre.winblue_ltsb.160611-0600
    PLATFORM ROLE Slate
    REPORT TIME 2016-07-1716:33:58
    Installed batteries
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1167530500
    CHEMISTRY LION
    FULL CHARGE CAPACITY 144 mWh
    CYCLE COUNT 286
    2016-03-06 - 2016-03-13 42,308 mWh 42,157 mWh
    2016-03-13 - 2016-03-20 40,464 mWh 42,157 mWh
    2016-03-20 - 2016-04-03 35,692 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 30,584 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 36,497 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 37,293 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 39,350 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 35,651 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 32,524 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 27,003 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 23,326 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 20,748 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 14,542 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 11,254 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 8,457 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 4,705 mWh 42,157 mWh
    2016-07-04 3,686 mWh 42,157 mWh
    2016-07-05 3,686 mWh 42,157 mWh
    2016-07-06 3,686 mWh 42,157 mWh
    2016-07-07 3,669 mWh 42,157 mWh
    2016-07-08 228 mWh 42,157 mWh
    2016-07-09 144 mWh 42,157 mWh
    2016-07-10 144 mWh 42,157 mWh
    2016-07-11 144 mWh 42,157 mWh
    2016-07-12 144 mWh 42,157 mWh
    2016-07-13 144 mWh 42,157 mWh
    2016-07-14 144 mWh 42,157 mWh
    2016-07-15 144 mWh 42,157 mWh
    2016-07-16 144 mWh 42,157 mWh
    2016-07-17T23:12:04+00:00
    Yes Simon - That's exactly what happened to me.  I run my SP3  docked 90% of the time.  Just over a week ago it started powering down randomly while it was docked.
