2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T08:41:33+00:00
    Hi everyone, My name is Dan first time here and i too suffer from crap batteryitis... haha anyway this is bull, so this hasn't been resolved yet? i just skimmed a few of the 86 pages. whats the 411 i spent so much on this for it to break down in a year! i already talked to the on twitter but they brushed me off and expect me to pay $99 to chat with them.
    2016-08-18T09:14:41+00:00
    I am having this issue with the LGC-LGC battery too - original post
    Performed a clean install on the 13th, so not sure where the extra data came from - must be held in UEFI?? or sim
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=ae5bf67f-f77c-4885-a29b-a79bf2e16716)
    2016-08-18T12:06:22+00:00
    I've been having a discussion with Barb Bowman on twitter around the SP3's that are so low on capacity that they no longer function when docked.  Are there SP3 owners on this topic that are also finding that the SP3, when at it's lowest capacity, is also unable to stay on even using the supplied power supply?  I'm sure some people said that was the case but we want to be sure.
    2016-08-18T12:08:21+00:00
    I think I've mentioned this before too but just in case, what about travelling with an SP3 that is unable to operate on battery at all because I thought in some countries it was a requirement to power on the device when going through security?  I think if it can't turn on you either have to give it up or decide not to take the flight because they will not let you take it on board if it can't power on?
