2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T04:19:23+00:00
    my Pro3 battery started dying soon after warranty got over and now (18month) its as good as non-existent. Doesn't last even a minute. MS moderator says its a vendor specific and asked me to post message here:
    >>MANUFACTURER         SIMPLO
    >>SERIAL NUMBER        1165302276
    >>CHEMISTRY            LION
    >>DESIGN CAPACITY      42,157 mWh
    >>FULL CHARGE CAPACITY 608 mWh <<<------
    >>CYCLE COUNT          176
    2016-08-18T05:11:09+00:00
    Mine degraded from 8% battery wear in the 12th month of ownership (February) to 100% wear two months after that. Can't believe M$ is turning a blind eye on an issue like this given the good financial condition of the company and the recent LI takeover. D**n it! I now have a bl***y dust collector on my desk and even the tiniest power outage shuts the whole thing down. Does anyone have the email for Panos Panay?
    2016-08-18T06:39:22+00:00
    AND WHAT IS THE SOLUTION?? I had to do a reset on my surface pro and lost all my applications that i installed because the surface pro kept shutting down everytime it is unplugged and the windows errored out. Even after a reset the usable battery capacity showing 140mwh .....I see a class action lawsuit if this is not remedied soon!
    2016-08-18T06:44:14+00:00
    check this out! from being normal to this in less than a month
