2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-17T20:59:23+00:00
    What brand is the battery?
    Have you applied all the updates? Hopefully that will solve your crashing issues.
    But it's good to know even after 400 cycles, the battery is holding majority of its design capacity.
    2016-08-17T23:06:30+00:00
    So check this news out...
    http://mspoweruser.com/microsoft-close-to-simplo-surface-pro-3-battery-issues-fix/
    Again, vague tweet is vague. Gives absolutely no indication as to when the fix will be rolled out. It also irks me that Mr. Hall would post this to twitter instead of the official forums. Guess he is too busy making advertisements about how he hates iPads so much. At least they say they are close to a fix though. . . whatever that means.
    2016-08-18T02:44:03+00:00
    So how many people here have completely bricked devices now?
    If the dock and AC adapter both can't supply enough power and the device uses the battery as a buffer, a firmware update might be pretty risky for a lot of us. On the other hand, the device is useless if it will not stay on anyways.
    Mine will shut off in the dock with the screen brightness more than 0% when under heavy loads.  Maybe I will just turn the SP3 screen off next.  I also read on here that the AC adapter is better but it still worries me that MS might be too late for a lot of people.
    If the batteries keep rapidly declining then time is a big issue on releasing this update.
